ET35 Offset Wheels
wutang200
8 January 2009
Just bought some Rota Torque 17" wheels that are ET35 all round. Will this look ok on an S15 Spec R with that offset or am I better off buying spacers for it?
If spacers are needed, what 'mm' do you recommend?
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
Spacers will be needed on the front, probably 5mm, the rears should be fine :thumbs:
Edit:
Nismo GT4's; 17 x 7.5" ET +30 at the front & 17 x 8.5" ET+40 at the rear
Works CR Kai's; 17 x 8" ET +32 at the front & 17 x 9" ET+30 at the rear
Standard arches & no spacers....
wutang200
8 January 2009
Thanks for that.
I already have 3mm spacers lying around which I can use for the front.
Will post pics up once the wheels are on the car.
If worst comes to worst, I'll swap the 3mm to the rears and buy 5mm for the fronts.
need to know what the width of the wheels are to know if the offset is any good:)
sounds good to me - may need spacers to beef the look up a bit but should fit perfectly as they are. my enkeis were et42 rear and et35 front on the same widths and fitted nicely
wutang200
8 January 2009
I'm on standard suspension and have no intentions of lowering it.
Here's pictures of my 17"x8"x ET 35 all round without spacers. They are Weds RS Sport which I use for track. They fill the guards fine.:D
29 May 2009
ireland
nice car lad!!!:thumbs:
^^ Thanks,when I get a chance I'll get some shots up with my street rims ;)
wutang200
8 January 2009
Damn I so need my wheels on my car! I've lost my locking wheel nut key so am in a bit of trouble trying to find someone who can remove the locking nuts.
29 April 2009
Wheels look great mate! Your headlights look pretty cool too! :cool:
V
vti_coupw
i love the back ones man they fit perfectly, i never under stand offset and all that, they look spot on just sit perfect with the archs, really look well under the white aswell
good work bud
C
cbarry
wheels suit car perfect!looks sweet:nod:
wutang200
8 January 2009
Thanks for the nice comments guys! I'm glad you guys like the new look. I'm also loving it too.
I was ready to sell the wheels off if they didn't look right on my car but now that they're on, it's spot on in my eyes.
I had a couple of 3mm spacers which I didn't bother fitting as the wheels fitted surprisingly perfect.
Trial_S15
13 July 2008
Meath, Ireland
:eek: Thats odd because I've very little space between the top of my 8" wide ET32's & the suspension strut?? Although the camber is probably causing that!
They really suit you car though :thumbs:
