ABS... light always on and without bulb abs OK?!
1 May 2015
The Netherlands
When I bought my S15 the ABS functioned as it should only the bulb didn't light up when the key is turned
So I putted in a new bulb, but now the bulb is lid (thats why they removed it i thought, so no surprises there) and the abs is turned off :S
Without bulb in the cluster the abs functions, and with it (lid) in the cluster the ABS is off?! (the manual point towards a connector of broken/damaged wiring)
does this mean i should get it checked at Nissan (hope not) cause i don't see any way to get a code from the car
NDS doesn't support ABS :( and there is no flashing trick thingy
Any input would be highly appreciated
So far:
-Fuses are all ok (2x 30A and 1x 10A)
-Connectors are all looking fresh
-Ground OK
-Power 12V to abs OK
next up:
1 May 2015
The Netherlands
Done the "service-manual checks" for "abs light always on" and all seems fine... hmmm
ground are all 0 [Ohm]
no broken wires or anything...
Any tips would be highly appriciated
anyone ever had a busted abs actuator?
1 May 2015
The Netherlands
Found it, right front sensor is knackered
1 May 2015
The Netherlands
First unplug the connector @ wheel arc inside (next to engine)
Take an ohm meter and check the resistance on the sensor (was 1.2k ohm) that means sensors are fine
Next reconnect connectors and disconnect the abs controller unit
Measure resistance here, should be 1.2k ohm
Mine right was infinite witch means open curcuit
Than narrow it down
If you need more help pm me
