- 26 October 2006
- Singapore
- www.imperial-concepts.com
Hi guys,
I am from a tropical country Singapore and have recently encounter a engine oil temperature issue which even my mechanic could not figure out, hopefully i can find the root of the problem with all your gathered experience and knowledge on S15.
Here it goes -
When i am cruising around 100km/hr regardless if its morning, noon or night, my defi oil temp would slowly rises to 100degree C but strangly defi water temp maintain to a steady region of 80 - 89degree C. When coming to a stop or if there is a traffic jam, oil temp would then steadily go down to around 90degree C.
So basically the main problem is only when cruising/travelling, oil temp will rise and hit the 100 mark whereas it use to be at the region of around 88degree C to max 92-93.
The weirdest part is, it does not increase when i am stuck in a bad jam with very hot weather only when cruising/travelling will the oil temp increase. My mech and friends was telling me that usually the water temp would rise higher 1st causing the oil temp to increase.
What i have done so far, was to flush my radiater to make sure there is no choke, adding fresh coolant in, changing temp sensor to make sure its not faulty and even changing to a new water pump but all these apparently didnt work.
So what may seems to be the problem?
- Fan clutch weakening? bearing slightly jam causing the fan to not be as strong when cruising?
- Head casket? - which i doubt, no flooding on my reserve water tank.
- Thermostat? - Hoses feels fine and heat normally.
Thank you all for taking the effort in reading and would appreciate for any helpful advice. Cheers
Here it goes -
