anyone know where to get a new AFM?
26 February 2010
england
as the tittle says i need a new air flow meter and its a nightmare trying to find one :( .
can anyone point me in the right direction i would be most greatful.
cheers
26 February 2010
england
standard mate.
a upgrade would mean changing a few more things wouldnt it?
24 January 2013
Kent
only the connection into the afm, so not much work really
26 February 2010
england
so basically just another pipe?will i need a different filter or anything and is it really worth doing?
and i take it the upgrade would be a z32?i asked my mate about that and he said i would need to get my ecu mapped with it to get it to work?or is this complete rubbish?
24 January 2013
Kent
Sorry I didn't describe it very well. The AFM is a straight swap but the plug that goes into it from the loom needs to be changed, you can pick one up on ebay for about £30 and all you do is cut the old plug off and then rewire the new one in- simple stuff. You don't need an ecu map, the sensor works in exactly the same way, you only upgrade if you are running more power. to get 300-320 from mine i was told i needed a z32 AFM (from the 300zx) hope that's helped
No you do need a remap to make a z32 Afm work properly! You can't just put a z32 on your current setup (if you have stock Afm) and expect it to run. They have different signals etc
The S14 Afm is the same as a s15, so look out for one of those 2nd hand otherwise Nissan is you best bet if you don't want 2nd hand.
24 January 2013
Kent
do you!? S*** as i was just gonna bolt mine straight on, i havent read that you needed to get ity mapped, steve at fc tuning just said i would need one to get to 300hp. whoops
No you definitely need to have the car mapped when you fit the z32 maf is why I haven't changed mine yet
24 January 2013
Kent
another job for steve when i get it mapped
24 January 2013
Kent
its ok thanks, seen your ad but getting a nistune from FCtuning
26 February 2010
england
looks like i would need a remap for the z32 then haha.maybe il stick to a standard one for now until it comes to that
