Battery Cut-off
I'm looking for a quick and easy way to disconnect my cars battery, at the moment i disconnect the negative side when the car is in storage. There are a lot of battery cut-off switches available, but i've been thinking of something along these lines -
http://shop1.actinicexpress.co.uk/shops/Rat_Sport/index.php?cat=Battery_12V__Sealed
The alternative is something like this -
http://www.driftworks.com/catalog/products/fia-approved-battery-cut-off-switch.html
The 2nd option doesnt look so easy to fit. Any thoughts or alternatives?
i have a set of these on the S15.
Very quick and good.
I have used both of these types of switches. The top one is quite easy and doesn't require any modification to the car. It can be easily removed if required.
The second type of switch requires some changes to the battery wiring and a spot to mount the switch.
It you are looking for something easy, use the top one.
sillbeers15
I have installed the 2nd option shown by Topper.
Works well when I store my ride. At least the battery don't go dead that soon.
Cheers guys, i think i'll run with the 1st option.
24 February 2006
Plymouth
Im just about to install the second option...
Sillbeer any tips? :)
i'm looking to get one of these too, and like the look of the first one (with green handle).
Do you know if its the smaller or larger battery connection/terminal size?
I think they are the larger. If you have small battery post you can get what they call a terminal sleeve and that should solve the problem.
but then i'd have to convert my original clamp to a large one, to fit on the other end of the cut off switch. Nothings ever simple is it!!
You can take the original clamp off and just use a terminal. there is a hole at the end of the cutoff switch. It is covered by the existing battery clamp.
Hope that makes sense.
Havent received this yet, but had a look in the engine bay, i dont have alot of room from my -ve side to the front support behind the lights, so fear this may not fit.... :rolleyes:
sillbeers15
Channie,
Straight forward installation.
Easy to use as any idot proof switches.
No complains.....
Can install at easy to reach for prevention against fire hazard or
install in hidden locations to act as security device.
24 February 2006
Plymouth
Channie,
No complains.....
Cheers! Gunna tackle it one night this week!
