MWTech
As an official BC dealer, Im pleased to offer these to forum members
Ok, there are 3 types available for the s15...
BR Series Street and Circuit Coilover
Pillowball upper mount
Camber adjustable top mounts
Aluminium top plates
30 way adjustable damping
Adjustable spring platform
Height adjustment via bottom mount to retain full damper travel
Bearing mounted upper front spring platform
Dust boot to protect damper seals
* some features are dependent on model
Spring rates for all systems are as follows : Front 6 Rear 5 ( Except for ER Series ) ( Harder or softer springs are also available on request too )
The BR series coilovers use a large 46mm diameter piston in a 53mm diameter damper body to maximise oil capacity.
As the damper unit opearates the oil contained within heats up. The viscosity of oil changes as its temperature varies which can lead to changes in the damping characteristic of the unit.
BC Racing only use a very high quality oil with their coilovers but go that extra mile to maximise performance and build their BR range with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil contained which in turn reduces the peak temperature and so significantly improves damper performance.
RM Series : Inverted Damper for Pro Track
Inverted monotube damper bodies
Inverted Damper :
The BC Racing RM series feature high quality damping adjustable monotube inverted dampers at the front or front and rear, depending on vehicle. The RM coilovers offer the majority of the features of the BR series but with the additional benefit of the inverted damper unit. Inverting the damper unit brings with it a number of advantages.
Unsprung weight is reduced by moving the oil and gas reservoir way from the hub and attaching it to the shell. Unsprung weight is vital to a cars performance as a lighter wheel and hub assembly which readily moves in response to road bumps will have more grip when tracking over an imperfect road.
External reservoir ER Series
BC Racings premium flagship coilovers are the external reservoir ER Series with separate compression and rebound damping adjustment. The ER Series coilovers bring with them the high quality and unique features seen on the BR and RM type but have the additional benefit of external reservoirs and the ability to allow the end user to individually adjust and set compression and rebound damping rates.
External reservoir
The external reservoir ER Series coilovers allow BC Racing to increase the oil capacity of the damper unit. The additional oil capacity reduces peak oil temperatures which decreases variations in damping rates due to oil viscosity changes. The reduction in damping rate variations improves handling and ultimate on road and track performance.
All prices include vat
BR series for forum members
£590 ( Retail - £649 )
RM series for forum members
£695 ( Retail - £759 )
ER series for forum members
£1140 ( Retail - £1249 )
However, for the first 3 customers, as if the price wasnt good enough, a special one off price of £575 for BR, £690 and £1115 for ER, So be quick!
delivery for all coilover products is £10 for UK and £19 for Ireland
Thanks
Inverted Damper :
External reservoir
Thanks
