Bent Valves!
9 September 2014
Sheffield, England
Wondering if any sr20 wizards could help me out?
My car isn't starting, took it to a specialist garage to where it has been before and they found the compression was very low. On further inspection almost all the valves were bent! It used to cough and splutter on full throttle when it was hot, I'm wondering if this was the cause.
Anyway what could cause this to happen? All I did was remove the cam cover to get it painted.
Thanks in advance
4 August 2011
Removing the rocker cover itself won't of effected anything unless you messed around with anything else. Could be that the timing has jumped a tooth or two if the chain was slack perhaps?
ive got a full set of valves and springs etc for sale if you need some.
9 September 2014
Sheffield, England
I did have a look around when I removed the cover and everything looked okay, it's a mystery.
I might just buy them off you! I'll let you know after the head has been removed, hopefully it's not done to much damage
Sent from my GT-I9505 using Tapatalk
How do you know the valves are bent?
But it it sounds like the timing jumped somehow!
9 September 2014
Sheffield, England
Because a technician told me haha.
It used to have compression of about 100 psi which is low isn't it? My car just goes wrong in ways no one can explain :(
4 August 2011
100psi is low off the top of my head it should be between 120-150 and equal across all four cylinders. The engine I sold last year was just over 140psi on all four.
9 September 2014
Sheffield, England
Update!
I'm having a new engine installed at slide motorsport.
It turns out my rocker cover was shot blasted even though I asked it to be dipped, oh well it was probably going to lose all compression at some point
18 September 2011
West Midlands, England
man iv'e heard so many horror stories about shotblasted rocker covers ruining engines............sorry to hear this dude, hope your back on the road soon.
Jaydej
6 December 2013
Herts
Sorry to hear dude
9 September 2014
Sheffield, England
It sucks lads :/
Cheers for the moral support!
Might be a dumb question but how does Shot Blasting a rocker cover ruin an engine ?
Jaydej
6 December 2013
Herts
I'm guessing maybe the fine material used to shot blast the rocker could stay on the inside of the rocker cover calling into the head. Personally I didn't realise there was a problem doing it, but I'm glad I haven't now
9 September 2014
Sheffield, England
Yeah that's exactly what happened :(. I have always had a feeling it wasn't the original engine or if it was, it had some serious hammer in its time
