Boost
23 April 2007
UK
Picked up my S just over a week ago. Amazing car but need to confirm something. Car currently has a HKS filter and exhaust. On idle, the boost gauge sits an -5. Pedal to the metal, best I get is .55. Is this right? If theres a crack in the WMIC pipes, is it better to replace the unit with an FMIC or just replaces the pipes bearing in mind that id rather not spend a lot right now.
Boost seems to be a little low.
Hmm, Check the vacuum hose which is Tee'd from the top hose comming from the BOV to the boost sender. It could have split somewhere.
The boost sender should be located on the driver side strut tower.
23 April 2007
UK
actually i havent. Is that when peak boost is achieved? I usually shift around 6k purely because im not used to the car yet. If it still doesnt achieve 0.7, any other things i should look out for? I checked the boost sender and it seems fine. Pablo warned me about them but i dont see any cracks.
sushiming
13 November 2005
Hong Kong
try driving it over 5.5k revs with the gas down it should get to 0.7bar.....cuz its normally 3.5k u get 0.55 boost then 5.5k u get 0.7bar boost seee if that works buddy u will be fine with the over that boost iam sure u can handle thats hehehe:thumbs:
23 April 2007
UK
well you guys were right!! At high revs, boost peaked at just under 0.8. After reading through past threads, seems this is fine.
