Broken o2 sensor?
21 July 2009
United Kingdom
Hey,
last month i had my car re mapped and ever since then its been running rather rich from idle and throughout the entire rev range whether on boost or not. I ws told at the time my lambda sensor was 'dead' however i just plugged my laptop into the consult port and the sensor is giving a reading...
was sat at 0.010v the went down to 0.0v after around a minute but just up to 0.180v when the throttle was blipped. The AFR was at 14-15:1 at this time (first time ive seen it above 12 since the map). The AFR then sat at 11.9-12:1 when idling once the car had warmed up and the o2 sensor output was 0.150 or 0.160v.
The car is absolutely munching through petrol and i assumed it was the sensor that was to blame but it is actually giving an output which i though was odd for a 'dead' sensor.
Also, there are no current or stored fault codes on the ecu.
Can anyone advise if this is usual behaviour for the lambda sensor or if i have another issue that need addressed? :confused:
thanks in advance.
drifter
4 April 2011
Norfolk
The standard o2 sensor should be bouncing between 0 and 1 volt all the time. If it sits at nearly 0 all the time like yours it will be dead :) Have a word with Jez at H Dev, he sells decent replacements :) Stay away from the cheapos (£30ish) imo, used 2 in the past, both ****e :nod:
I bought my o2 sensor through ebay from the states as it was way cheaper at the time.
21 July 2009
United Kingdom
Yeah i seen a Nissan dealer selling them on ebay for £50 which is decent.
So the sensor voltage should be fluctuating constantly- is there any other way i could test it?
Its just money is tight and i don't want to spend money on a sensor if its not definitely the problem.
Yep, put a Multi Meter on it and check the voltage as you rev the engine
21 July 2009
United Kingdom
Checked it again after charging my (pathetically poor) laptop overnight and the voltage fluctuated a couple of time when i started the data scan program then it went flat to 0.000v and AFR was sat around 11.4:1. It was making the car misfire a few times too :s
I had a look at the sensor too and theres a dent in the outer metal casing- coincidence perhaps but it could possibly be damage to the ceramic element inside.
Think a new o2 sensor is next on the shopping list along side Okada projects or Splitfire coil packs.
21 July 2009
United Kingdom
Those Okada coils look spangly :D Don't like the price much though :(
If you need coils take a look at these...
http://www.ebay.co.uk/itm/YELLOW-JA...arts_Vehicles_CarParts_SM&hash=item48419f417e
I'm still on standard coils even with the boost I run, if and when it starts to play up I'm gonna try the Yellow Jackets :)
I'm still on standard coils too but last twice i went for a map i've been told the coils are on there last legs. The yellow jackets look cool B) never heard of many people running them though
