E
Endless
Hi all, I have a 99 Spec R and my engine seems to be having the problem of burning (vapourize) engine oil for the past 6 months. Currently, after engine oil change (synthetic), I can only drive for around 1500KM before most of the oil turn dark and come to the low level on the dip stick indicator. I have ask my mechanic to check, he said all of the pipes seems to be ok, he thinks is my head gasket that is leaking, he told me it is only minor leaking and I just need to check my oil and coolant level every week then it should be ok. My car runs fine right after oil change, but after 1500km or so it start to feel sluggish, and when I open my radiator cap it had the popping sound, and coolant run out faster than usual too, and this does bother me...what do you think the problem might be? if is really the head gasket leaking, is it expensive to fix?
