BZZZZZ Boost Solinoid
T
Toby
Recently fitted a Gizzmo Boost controller, It works great, but when I turn the ignition on the boost solinoid makes a very loud BUZZZ noise.
Any idea why this is I have read somewhere the ABS unit can do it, but when I unplug the valve it stops...
Thanks all!
GUEST_JDM
do you have the valve wired reverse by any chance? as im pritty sure the gizmo unit has a inline diode inside the cable near the connector
T
Toby
Not Possible mate, the clip on the harness will only connect 1 way round....
That's really strange dude... mine has never made a noise since fitting it?!
Fook sake it has now!!!
My Gizzmo is buzzing like a damn vibrator (not that I know what a vibrator buzzes like lol) when I turn ignition on. This has only started today since I had an 'incident' where my earthing cables melted after something shorted with possibly the alternator LIVE - and all this in the middle of an unplugged fuel filter with fuel everywhere??!! :wack:
Damn it's been a bad weekend grrrrr :(
T
Toby
Grr I hate wiring when it goes wrong, like a pin in a hay stack!
Maybe when I drop the engine back in it will magically go away lol!
So in otherwords its 90% likely to be a dodgy earth..
Well dodgy earth has gone away for now and I re-insulated everything so really not sure why the buzzing has started...
Although I went back to car just now and turned over ignition - NOTHING :wack:
So it looks intermittent damn it grrr!!!
intermittent problems are so annoying. At least if it is happening all the time you can track it down.
Well hopefully it's gone away for now lol :wack: Not done it this morning. Electrics are all being checked by auto electrician today so wait to see if anything looks damaged...
