Clutch Gearbox Noise.... Answer
8 May 2006
Dublin , Ireland
Right Guys..
This is the answer to alot of peoples problem with upgraded Clutch noises.
found this when browsing through the nismo site
http://www.nismo.co.jp/en/products/competition/clutch/lineup.html
  • Because the lightweight flywheel has been designed and manufactured to provide improved clutch response and output, it is possible that the transmission or bearings may make a rumbling noise, particularly in comparison to genuine Nissan parts. Transmission or gear noise is most likely to occur at idling or when accelerating or decelerating in the range of approximately 2000rpm; however, this has no effect on quality or performance. For those concerned about vibration and noise, the use of a genuine flywheel is suggested.
jhinchy
That confirms that so!
aahh! thanks mate, that sort of sums up my problems tbh, still dont understand why c1tpt has the same one fitted and no noise but his spec is probably different to mine so too many variables. why dont they do a decent strong organic for these.....:rolleyes: they do the act clutches for the s14a that take loads of power
