- 18 November 2008
- Hants, UK
- www.skewer.co.uk
Not sure if this is electrical or mechanical, so putting it here. Had a search on idle and adjusting and didn't really find a difinitive answer to the issue I have.
Basicly, when cold the idle is way too high, something close to 2000rpm. Then, when I reverse off the drive and dip the clutch to change into first it'll go upto 2300rpm, sometimes more. That can't be right!
Had a look at it this morning and have made some adjustments. There's a little piston underneath the throttle butterfly switch which looks to adjust the throttle stop position. Having cold started it and shoved it this way and that I've adjusted the idle screw on that so it sits lower and doesn't hold the butterfly open so much. Then also adjusted the normal idle screw out a little as warm idle was around 1200rpm. Have got warm idle down to 1000 but it's obviously still a little high and I can't really see where to adjust it further (there is more room on the idle screw but the butterfly doesn't quite reach it now, even when warm - possibly need to adjust the cold idle bit again)
I've given the piston mechanism and surrounding area a spray over with GT85 incase it's a bit sticky.
Anyway, just wondering if anyone knew a 'oh yes, it's this' for this one. I've cleaned out the butterfly as it was a bit gummed up but have not yet removed and cleaned the idle control valve, or anything on the AFM. Guidance appreciated :thumbs:
