Defi BF bosst meter problem!!!!!!
130r
Since the oem boost meter is down, i took the opportunity to install
a Defi BF boost meter.
I follow the instruction, installed within 2 hours. Unfortuntely after the opengine sequence, the light goes off but the boost is still functioning. It only illuminate when the light is turn on.
Unplug the meter and plug into my friend's cars hardness and it works.
What could be the problem. I am using the cigarate lighter wire for the 12v power.
Could it be the Link Control unit?
Regards
I've got a similar problem with mine at the moment. The Control Unit has been tested on a mate's Defis and is fine. Most likely to be a dodgy connection.
130r
Problem solve :)
Regards
130r said:
Problem solve :)
Regards
What did you do to make it work alright?
130r
To move the power source from output 1 to output 2.
Yakozan said:
130r said:
Problem solve :)
Regards
SR2O
31 August 2006
Melbourne, Victoria
I've got a Defi BF Boost Gauge and Control Unit arriving in the next day or two so I've been doing some reading on the installation and came across something interesting..
The control unit as you know has two meter output ports; both of you used the first meter output port and ran into trouble. The reason this has happened is not because you have a dodgy output port but because the two ports are designed for two different types of Defi gauges.
The first meter outport port is intended only for Defi Link Gauges (non black face when power is off) and the second is for Defi BF Link Gauges (black when power is off)
This information is confirmed on page 80 of the installation manual:
http://www.nippon-seiki.co.jp/defishop/product/images/dlink-manual06064e.pdf
So there you have it, I hope this clears up any confusion for anyone else who installs these gauges.
8 May 2006
Dublin , Ireland
yeap i saw that page too when i was installing mine hehehe. no problem installing mine at all.
only thing i hate is the oil pressure gauge. cant get rid of that dam buzzing sound when i want to listen to the radio when the cars not running.
Your stereo should be wired to the the 1st ignition position and the Defi controller to the 2nd. I can listen to mine fine on the 1st position :)
Mine stereo is plugged straight into the existing connectors with a converter, and the Controller is going to a main ignition source. You haven't wired your Controller into the stereo loom, have you?
That'll be it then. Try moving the Controller's ignition onto something on the second ignition position (when the warning lights come on). The lighter would be a good one to try (test it first) :)
8 May 2006
Dublin , Ireland
ok just got the time to try the lighter.
ok can confirm that lighter is on postion one.
you know any other postion 2 i could try?
mine are wired through my stereo... and work fine...?
I do also have an oil pressure gauge that constantly beeps if the engine isn't running... this would be due to position 1 and not 2... but it doesn't bother me enough to rewire! lol
8 May 2006
Dublin , Ireland
it's been a while but i've finally found a source for the secound ingnition wire. pulled it off the ingintion it self. since i have a turbo timer wired i pulled it off the wiring harness.
there only 3 wire red, green and blue.
as stated on the tt manual
red = 12volts constant
Green = ingintion one
Blue = ingintion two
have my defi wired to green as ive tried blue did not work.
