Defi boost gauge
5 January 2007
Ballymena N.I.
Where would be the cheapest place to get a defi bf boost gauge and control unit in ur peoples vast experience.
Regards
Robby p
i've got on the way from japan... defi boost, oil pressure and unit 2... works out at 230 plus shipping.
shame you didn't say sooner, coulda shipped you a set round with mine at the same time...
got mine from perfectrun...
I'm with nicely on this one. nengun is the cheapest I've found.
But if you prefer faster shipments, I wouldn't hesitate using perfectrun instead. depends on if you're in a hurry or not.
price difference between the 2 weren't much really... considering i ordered injectors and the new HKS EVC at the same time... broke about even and quicker delivery...
5 January 2007
Ballymena N.I.
thanks for the info there lads will check out both sites.Can u just order the bits online?Also do u get an adapter th plug in for the oil pressure and oil and water temp?
can't answer, cause mine haven't arrived, hopin' for them to get here this next week some time. :)
Yes. they have on-line ordering.
You'll got to have something to fit the senders to though.
I would recommend getting a sandwhich plate if you want oil-pressure or temp and a radiator hose adapter if you want water temp. Greddy hos both in their lineup. But there is also cheaper stuff about which would do the same job.
i've already got an oil pressure gauge.... so i'd assume i've already got a sandwich plate.... but, it currently has a long braided hose on it, going all the way into the dash...
Sounds like a mechanic gauge.
I personally wouldn't feel very comfortable with a mechanical for oil pressure. But I've had some bad experiences regarding oil stuff, so it's probobly just me.
There are other ways to fit the senders. Some fit it instead of the stock oil pressure sender which don't do much good anyway.
well... guess i'll have to see how the defi works...
the one i've got is a mechanical... one reason why i'm changing it... there's a slight rattle from it, and it bugs me! haha!
8 May 2006
Dublin , Ireland
defi BF's are great got oil pressure, oil temp, fuel pressure and boost. the controller is really good too. very easy to install.
got 3 of them in my centre vents looks amazing.
i got a friend that was in Hong Kong to bring them back so saved abit on delivery
sushiming
13 November 2005
Hong Kong
i got the boost and oil pressure ones and the unit sitting in my room heheh
H
Hank S15
I`ll call your boost and oil pressure gauge, and I`ll raise you a watertemp and oiltemp gauge! :D
Just got them in yesterday from Nengun, cheap and fast!
b.t.w, what`s the best sandwich plate to get?
8 May 2006
Dublin , Ireland
well ive got a thrust/Greddy oil filter moval kit, it relocates the oilfilter to a easy access position. also has taps in it for oil temp and oil press sensors. also easy to upgrade to a oil cooler later as pumbing is all there at easy access.
H
Hank S15
Been looking for the Grex moval kit.. but somehow can`t find it for the S15.
Only S14.
Will this fit also?
H
Hank S15
Oke cool... better to know for sure then to guess ;)
The S15 is a S14 with a factory bodykit anyways :D
