Differences between S14A/S15 FMIC
13 November 2006
Swindon, UK
Are there any. I need one for the ESVA test. If there are diffs then i'll have to source an S15 one instead on an S14A.
Help.
They are no difference that they'll be able to tell.
The S15 WMIC is 33% thicker. All the mountings and pipes are exactly the same.
And the cold pipe doesn't have the resonator on the S15 (does fook all)
Help.
FMIC is the same.
If you meant the stock WMIC they are not the same.
S15 is about 33% bigger.
who told you that you can't use a S14 item?
I sincerely don't think they will see any difference unless comparing it side by side.
The S15 is the same widths. Only thicker.
Edit: Nicely beat me to it.
13 November 2006
Swindon, UK
My suspicions were aroused by the lack of a resonator box. I thought there may be other difference.
Looks like i'm ok then.
13 November 2006
Swindon, UK
I just hope they don't complain about the resonator.
I honestly can't see what they could complain about. The only reason the resonator was fitted was to reduce induction noise. If anything, there's more argument for it BEING there...
