ecu pin out help
29 July 2010
Wales
im wiring in the power fc D jetro and the wire for the intake temp has to go to a location in the ecu plug that has no pin.
my plan is to find the pin for the maf sensor, cut it and leave a length of wire on it then use that pin and solder the intake temp wire to that but here is my problem :nod:
I have been hunting on the net for ages and keep finding different pin outs so im not 100% what wire the maf sensor is :confused:
does anyone have a spot on ecu pin out of an s15 spec r?
cheers :thumbs:
24 January 2013
Kent
have you used the online service manual in the useful threads? has all the wiring diagrams you ever need for the 15
29 July 2010
Wales
I've looked up the pinout in the service manual In the useful section and it does not match up with what wires I have in my loom?
24 January 2013
Kent
The thermal transmitter is F117 under the inlet manifold (I assume you knew this?) I think finding the wire will be in the EC or EL section of the service manual
I have looked a little bit but cant find nothing, its going to be in with the sensor wiring i think. Hope that helps a bit.
16 August 2013
W.Mids
Aussie cars don't share the same pinout as the JDM ones which most people here will have, just so everybody is aware of that.
29 July 2010
Wales
Ah right so the manual most people have is the Aussie one? My car is a jdm
16 August 2013
W.Mids
The only one available in English is the ADM one.
29 July 2010
Wales
Aahhh so this is why my wires don't match :nod:
29 July 2010
Wales
bump. can anyone with a djetro check the wiring to see where the sensor is spliced into?
drifter
4 April 2011
Norfolk
I can check mine when I get home :)
29 July 2010
Wales
That would be great, and if you could take a pic too even better :wave:
drifter
4 April 2011
Norfolk
Hopefully these will help :)
29 July 2010
Wales
life saver! :rotfl:
2 October 2013
northampton
hey guys, im havingtrouble with my power fc on my car harness pin 38 is empy and 39 is power but on the pin guide i have this doesnt match up what did you guys have
29 July 2010
Wales
Im in the middle of sorting a how to guide for this as it took me ages to find someone who was willing to take photos of their wiring ( cheers Drifter :wave: ) will post it up soon
29 July 2010
Wales
will sort it later today:nod: forgot all about it, my bad :down:
