blinx
I'm selling a brand new and unused RED-DOT Racing Front Discs and Pads for the S14/a/15 turbo version.
RED-DOT Racing Front Discs (Drilled and Slotted)
Type: FF3144
The Drilled & grooved range of discs deglaze the pad and vent gasses that build up between disc and pad during braking. As a result brake fade is significantly reduced.
The additional drillings dissipate heat more effectively giving an increase in performance than the XJ range. Suitable for road and light competition use..
Price - ? 180.00 + P&P
RED-DOT Racing Front Brake Pads
Type: XE3143
XE Fast Road Brake Pads
Description of Material
Red Dot Fast Road Compound is a Kevlar asbestos free material with a nominal coefficient of friction of 0.48. This material has excellent friction and wear properties over a wide range of temperatures, working consistently well from cold up to 500c. Wear rates are similar to those of standard road going material
Applications
Fast Road use, saloons, hot hatches and lightly modified vehicles. This material has been developed for the high performance road vehicle. It’s temperature stability combined with good wear resistance and quiet operation make it ideal for fast road used.
Price - ? 70.00 + P&P
Buy both together and you will only pay ?235 + P&P
Type: FF3144
Type: XE3143
Applications
