Fuses
Mycool
3 January 2014
Gloucester
@S15_wot
Hi all - basically iv came across something really odd today with my s15... My rear plate bulb had blown so i ordered some new led bulbs for it, fitted them & they still wouldnt work - so i automatically thought maybe there not working because there led, so i went out & got some normal bulbs, they didnt work either so then i checked the obvious, fuses! & the fuse was gone so thats that problem solved, While i was at it i checked all fuses & i found one that was blown so i replaced it with the same fuse, got in my car to drive as normal & it was misfiring like f**k. Took the fuse back out and it was fine, ive looked up what the fuse was and its an 'engine control' fuse. Is there any reason why when theres a fuse in it runs sh*t & when theres no fuse the car runs fine.... Is it important to have? Ive got no idea - ive tried to look it up & ive not had much luck there either, any help would be appreciated, thanks
15 June 2010
Gloucester
Pop to mine tomorrow if you want and I'll have a look at the faults for you
