Gauges...Once again!
Y
YazS150
I dont want to install in the vents because I luv my aircon too much. I like the cold! Where can I get an A pillar gauge pod thingy. CHeers guys!!
i've one in a vent's and it doesn't restrict how cold the car gets in any way.....
60mm gauges will fit in the pod. You just need to shave some plastic from the inside pod surround. Fitting one gauge into the centre vent won't effect your ventilation very much. With a great deal of indecision, I did this and found it wasn't a problem. :)
Y
YazS150
so nobody makes an A pillar pod? i just want to add an oil temp gauge:confused:
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
out of interest have you actually looked or did u just post in here straight away? All the info we pass to you can be found online. Its just a case of taking some time and searching for it.
Im sure their are companies that make custom A Pillar's for s15's. Check with EPRacing, Ebay, Apex? or on the SXOC however i dont think its a common mod within s15 ownersd due to the fact their are better places to put them.
just my 2p but iv found that by doing some looking around before hand earns you that bit more respect than being spoon fed everything. :wack:
Pazz
Well as we all know, forums have a search facility for a reason. But just like the SXOC, not many people use it.
U
Ucantry
if you dont want to use the air vents you can look into getting the border gauge pod, they make it for a s15
sushiming
13 November 2005
Hong Kong
or u could just stand them above the air vents which i was gonna but but changed my mind as i needed to sell....
there is a how to remove standard boost gauge have a look there and please using the search button first does help
