Firstly I would like to apologise as I want meant to go really into detail but I got carried away doing more then one job at the same time so. Missed out some pics but this should still help. Also some of the pictures aren't the best as I now and again remembers to take a picture.
but here we go.
1. Remove all 4 screws from to remove the black grill
2. If you look just behind you head lights you should see a plug that isn't connected to anything.
3. With abit of wiggling find a route to pull the wires down to the fog light whole.
4. Find some clips to bolt on the fogs to the bumper, you can you a nut with a washer as you have space to get a spanner behind.
5. Now fit the fogs onto the bumper.
6. Now you need to fit the stalk with the fog switch
7. Pop out the surround of the ignition
and yes that is a animal plaster, a bulb broke in my finger.
8. Unscrew all the screws from under the steering wheel cover.
9. Take both covers off. To show the stalk base.
10. Unscrew both screws and pull straight out.
11. Press down the clip and pull on the plug to release them from the stalk.
12. Get the new plug and do the reverse order of stages 11 to 7.
Notice that the new stalk has a extra stalk make sure to connect this as it is especially for the fogs
13. Once all fitted back to together onto the relay
14. Pop off the cover for the fuse box in the engine pay.
some S15 may already have the relay if you see this space blank you need to buy on from nissan go to the end of this thread to see the part numbers.
14. New test your fogs. If all working fit the front grills.
Part numbers
and I believe this is the stalk part number
enjoy all hope this helps
but here we go.
Part numbers
