hks evc install
davib
hi guys,
i have an old evc lying around
thought i try installing it, if im deemed capable
i understand everything already under some reading
LOL - i just found out the s15 was internal wastegates :annoyed:
anyways, my question is -
red is 12v power - would u go under the steering column and find a 12v (constant via ignition) ?
black is ground - but where do you ground in the cabin ????
im such a n00b .... but please excuse me, i find this forum educated and nice.
unlike nissansilvia in australia back home, its so rude sometimes.
david
Depends on where you are mounting it mate you can get power from there if you are mounting it on the steering column,all you need to earth is a bare metal ground really,you can use the stereo cage to earth off it is near where you are mounting.
davib
hi peg,
thanks for the reply.
i've never been under the steering column to do wiring,
am i safe to say i shold be looking for the red wire ?
or do i need a volt metre to determine a constant 12v volt when ignition is on ?
davib
hey guys
this is evc from installation manual, you see how its 3 valve ports
CAn you tell me if this is corect?
B
Blackstar
mate, with your solenoid pointing (going from left to right) outlet one connects to number 1 in your photo, outlet 2 connects to number 3 in your photo and outlet 3 you have to tap it into your fuel reg line.
ADMIN EDIT: Please do not use text speak. Read the rules
