E
ecksjay
I have for sale a full set of HKS 'Power' electronic gauges, all 60mm, with original HKS stands, blue faced/silver bezel, in absolutely cracking condition, including all necessary sensors AND a Greddy SR20 sandwich plate.
The gauges consist of boost (reads from 0-2.5bar), oil pressure and oil temperature. The temp gauge could easily be used as a water temp gauge without problems, you'd just need to tap it into the radiator hose, if so required.
The gauges were removed from an s14 silvia in japan and imported by me through the yahoo auctions. All have been tested on a 12v supply to ensure they are working. They all power-up and illuminate without problems, and go through the stepper motor sweeping motions as you would expect (defi-esque). I need to sell them to pay for a new turbo, as i'm upgrading.
The wiring harness has been combined to ease for wiring within the vehicle - each gauge uses three live feeds, one orange, one red and one yellow, which have been simplified so that you only need to wire one feed for each supply, same with the earth. This was done in japan but was very easy to figure out, and made things alot simpler and neater (...relatively).
The oil pressure sensor and pressure unit is included, as is the temperature sensor, and the boost sensor. All wiring is in tact and fully functional, as can be seen from the pics (it looks messy, but it is all connected and perfect, there is plenty of cable to route the cables wherever you need).
The documents below are the full instruction manuals for the gauges, detailing their full functionality, which includes - Peak Hold, Warning LED (and buzzer, if connected to an external buzzer), Playback mode (for monitoring, recording and playback of the gauge information)
http://www.2shared.com/file/5535388/9d27b7b2/60mmPHW20Boost.html
http://www.2shared.com/file/5535404/59076714/60mmPHW20OP.html
http://www.2shared.com/file/5535406/b7090638/60mmPHW20temp.html
The temp one comes up as the EGT gauge, which is obviously still a temperature sensor, just the gauge itself will be slightly different (different temp range etc).
I have uploaded a video showing the stepper motor and temperature sensor functionality, hopefully it should be enough information for everyone
Power up - http://www.youtube.com/watch?v=_rTceO3ypks
Temp sensor test - http://www.youtube.com/watch?v=1yNxiXlv9es
The noise in the vids is the computer turning on, not the gauge.
Loads more photos can be found here:- http://s181.photobucket.com/albums/x158/secksjay/HKS Power Gauges/
These gauges retail at over £120 each when new, not including the adaptor plate or stands.
I would like £275 delivered (within the UK) for them, considering they are in perfect condition.
Any questions, don't hesitate to contact me (pm for phone number/questions or email at ecksjay@gmail.com)
Thanks
Thanks
