how do you do to clean up the inside of the headlight ?
10 November 2006
France
hi there
i have some mark in he inside of the heaad lamp but i don't know how to do ...
sooo if you know ... ^^^
thanks
StarletRick
if youre referring to that yellowy coloured stain. its on the outside. all plastic lenses get it.
some cutting compound will sort it out.
Autosol is also very good for it, it just takes some elbow grease.
or you could buy some of that meguiars plastic polish and go at it with an electric mop. only takes 2 minutes and they look good as new ^^
aye, that's what i did with mine.... polisher and they were like glass again! :D
10 November 2006
France
thanks you
but i have try with the meguiars plastX and the outside is very clean ^^ but in the inside it is like burn of the plastic but I do not manage to unsettle them has cause of the glue :s
There is a way of splitting them apart to clean the inside too. This is the guide here. (Found in useful links)
i did the oven trick on my civic lights to seperate them to paint the insides met' grey.
just be careful not to cook to melting point.
19 June 2007
Essex / UK
I wet n' dry my lights. When sanding them the water was a yellowy colour and i kept sanding till it went white. Used some rubbing compund, then T-Cut and then polish = good as new :)
