MWTech
HSD Coilovers
The HSD HR coilover is exactly what the performance tuning scene has been crying out for. No longer do you have to accept an inferior/compromised product when spending less than £1000 on coilover suspension.
The HSD HR has been specced by HSD Europe, for our roads, and tracks, with the knowledge and experience gained by HSD Europe using the now world famous Driftworks Control System Coilover made by HSD.
HSD Coilovers use a very well respected and proven Monotube damper design combined with high quality hardware. This level of quality and performance is usually found on much more expensive suspension products. This is high end competition winning suspension available direct from the factory at affordable prices.
High Quality Monotube Dampers
HSD Spring and DamperDue to the excellent handling characteristics of the Monotube dampers, HSD coilovers give a supple, sporty and perfectly damped ride.
They soak up bumps and jolts effortlessly, yet firm up when needed to give exceptional roadholding and handling on fast road and track.
Cheaper aftermarket dampers use a twin-tube design with low pressure gas whereas HSD use Monotube damper design uses large diameter pistons and a much higher gas pressure to better stabilise the oil within, even under extreme and prolonged use.
Height Adjustment
HSD Coilover Height Adjustment Ride height is fully adjustable on all coilovers by adjusting where the mounting bracket sits on the damper.
This means a very wide range of height adjustment is possible without affecting the spring pre-load or the damper stroke length. So whether you want sporty or totally slammed, you still get the full performance of the damper.
Fully Adjustable Damping
HSD Damping Adjustment Our 16 Stage damping adjustment allows quick, easy and accurate control of the damping so you can tune it to suit your style and setup.
Set to soft for your daily drive, then quickly switch to hard for track days or competition use.
Pillowball Top Mounts ( Only available on the front of the S15 )
Pillowball Top Mounts. The coilovers come with Anodised Aluminium top mounts with integrated heavy duty noise-free pillowball bearings all round. This means you receive a complete package where the damper is precisely connected and working in tune with your car.
A wide range of camber adjustment is included on front strut models.
Spring rates are 7 KG/mm front and 5 KG/mm rear
Strict trading rules set out by HSD does not allow me to give any discount!! Really sorry
However...I will absorb the added UK delivery costs so it costs you nothing! The best I can do
Hope you understand
Including VAT, The price is £760
Delivery to UK mainland is free!
Height Adjustment
