sammos13
I have rebuilt my engine, nothing mega just a refresh with new bearings the only other additional that could effect running is a pair of 256 deg cams. now I have some issues with running, its very rough / spluttery and can develop a miss fire this is whilst idling and no load rev up. I've also fitted a Apexi PFC D-jetro in combination with the rebuild and want to get some experiences to help track down my issue. so far I have:
retimed CAS as per manual (15 deg when hot)
fuel rail pressure set at ca 38-40psi at idle
checked for air leaks, found none etcs
wapped out the plugs for a new set
now at the minute i'm possibly thinking it could be down to the battery voltage, the PFC and metering the battery say its at approx. 11.5-11.8 v. to my understanding it should be around 14.4v so I am thinking its a dead-ish battery (oldish battery) or the alternator isn't charging the battery.
what does the hand commander normally show for voltage?the PFC is running a base map so I don't expect it to be excellent at idle but it seems very rough cold or warm.anyone got any others things to check? or issues people have seen before?
cheers
cheers
