Loose coilover upper mount?
1 March 2010
Yamanashi, Japan
I have a set of d-max super street coilovers, and the upper mount for the front drivers side seems excessively loose.
When I removed the coilover assembly from the car, i noticed that i can pivot the top mount with barely no resistance, while the passenger side required a bit of force. When i bought the coilovers new (approx 2 months ago), both sides had resistance comparable to the aforementioned passenger side top mount.
I also want to mention that I tried tightening the top nut, but i cant seem to loosen or tighten it...
Anybody have any advice on how to fix this?
Send them back if you can!
Most likely a sypherical bearing failure in the top mount, will require rebuilding by Dmax or replacing!
16 August 2013
W.Mids
Warranty job for sure, pillow ball bearings should be very tight.
