need a cure for squeeky brakes.
8 May 2006
Dublin , Ireland
right,
Just lately the cars had a case of squeeky brakes... while braking gentlely in the rain and dry.
can see any problems with the brakes plenty of pad on it front and back.
dont have and squeeking when i brake hard..
would i need now brake pad, disc. or could it be a loose bolt.. ?
getting very loud too now. :rant:
Speedy
Are the shims/pad attachments squeezed in towards the disc? Stones in behind the guard? might be worth taking the wheels off to check these points but someone else here might have had the same fault :thumbs:
raytsang said:
copper slip on shims?? whats that??
That's the stuff that helps the anti-squeal shims stop the pads from squealing... Copper slip is copper grease. Put a thin layer over the shims and replace.
I was asking if you had Mintex pads, as they have a reputation for squealing.
8 May 2006
Dublin , Ireland
ah icic.. will do that..
dont know if it is mintex pad. never touched the pads since i got it.
