Nismo Coppermix Clutch
Hey guys,
I've just got my nismo single plate coppermix clutch put in last month together with nismo big operating cylinder and nismo braided clutch line
Normal driving is ok however on high revs, it's harder to get into gear
Mechanic reckons the nismo big operating cylinder causes disengaging issue with the coppermix
Personally i've never heard of it but there is couple of threads on SAU but they are talking about using it with the nismo twin coppermix clutch
Anyone running it both the with no issues?
Might try rebleed and see if it helps
Sounds odd to me! Why would a heavy duty slave cylinder cause disengaging issues?! It should help it disengage. The only thing that could be wrong is its very slightly too short, your syncros in your box are knackered (did you change to a different gearbox oil when you changed your clutch?). Or as you say it might need a re-bleed. Unlikely but you never know!
http://www.nismo.co.jp/en/products/competition/clutch/lineup.html
Do not use the SUPER COPPERMIX with a Big Operating Cylinder. This can result in blocking proper disengagemnt of the gears because of insufficient stroke volume.
Right from the Nismo website! why they are selling the big operating cylinder is beyond me
Will swap back to the stock one now
Have you removed all that excessive clutch hydraulic line thats attached to the chassis rail. If you shorten it you will get better pedal feel.
31 January 2010
Australia NT
im gonna be a ecco and repeat what everyone is saying
DON'T USE NISMO BIG OPERATING CYLINDER ON SINGLE PLATE!!!!!!! lol
big no no you need more stroke for the single plate. leave the OEM slave in.
IF anything get he nismo clutch pedal bracket if ya in a hot climate. i bent mine a few years ago with this clutch.
Auss15: Not too sure on that but it's not the pedal feel, it's the slave not disengaging the clutch properly, ok on normal revs but just on high revs gears are hard to get in
Ironside: Yeah learned it the hard way, didnt think there would be an issue, will be swapping back to stock one which i kept luckily
1 March 2011
leicester
I have a nismo slave cylinder and copper mix clutch working fine but was on the car when I bought it so probably won't be much help! :(
