oil sandwich plate
Anyone know where I can get a decent sandwich plate from?
Have just fitted a defi oil temp gauge and need a plate for the sensor,any ideas?
Why have you removed it when fitting the oil cooler,just out of interest as I have an oil cooler on mine already,can you not use them together ?
drifter
4 April 2011
Norfolk
You can stack them up, I removed the standard oil pressure sensor and put the oil temp in the sump :)
Cool cheers buddy,not sure what I am going to do now
I found a greddy temp sender box mixed in with all the wiring behind my dash,I followed the cable and it seems to be going to the sump,so I might just swap that sensor for the defi one and run it from the sump,is the oil temp as accurate from there?
drifter
4 April 2011
Norfolk
Not really tbh, I'm trying to get mine in another location if I can. It does work but shows the oil at a lower temp so it might look okay on the guage, but at the filter it could be a lot hotter :) I've learnt to allow for it, my oil is okay upto 150degC so the gauge alarms at 120degC :)
Ok cool,so are sandwich plate ok when they are stacked then,they don't leak or anything as I might still go with the plate in that case.
drifter
4 April 2011
Norfolk
Seems there is plenty of people on the SXOC who have them stacked up with no issues :)
