Parts To Fit Whilst Gearbox Is Off?
21 May 2012
Stirling, Scotland
Much like the title says, I've got a new clutch and flywheel on the way, so i was wondering what sort of extra parts should I fit whilst the gearbox is off. I'm meaning things such as an uprated pivot, braided clutch line. I've already got a nismo 'box mount, what else have I overlooked that would be worthwhile doing?
Release bearing?
New spigot bearing? Alittle tricky to fit as its in the end of the flywheel, and you need to pop it out using the old grease with tight fitting round bar or cut it out. And tap the new one home. Its a brass bush though so it very soft. They are £5 from nissan so cheap.
Uprated pivot and braided line defo worth it. With braided make sure it cutouts the damper line. Buy brake fluid too to bleed it.
Gearbox oil change?
Engine mounts as its alot easier when the box is off.
21 May 2012
Stirling, Scotland
The kit comes with a new release bearing. Not sure about the spigot one though. I changed the oil 2000miles ago so happy with that and I did the engine mounts at the same time as the gearbox one.
18 September 2011
West Midlands, England
21 May 2012
Stirling, Scotland
Cheers for the link. I was going to go for a hel one just never had time to get on the hel website yet.
