FS: R33 Brembo Front brakes & R33 Twinpot Rear brakes
17 August 2015
UK
Now Sold
Hi S15 owners, I was posting this up on the SXOC, where I'm a long standing member, and I thought you could be interested too, some of you already know me through my work - sure you can get it from the account name, not here to plug that,
R33 GTR front Brembo setup Direct S14/S15 fit, no mods/brakets etc, Includes:
R33 GTR Brembo callipers, good condition, not heat marked or chipped up
Ferodo DS2500 pads, about half worn, best road/track pad
324mm Original disks low mileage, no lip, not cracked, not warped
Correct bolts/washers, high tensile etc
These front brakes give excellent performance and are a direct fit replacement for std brakes, no mods required. fit under 17" rims. These are for sale in EXCHANGE for your std S14/S15 front setup. Must be good condition, all working, decent pads not warped. £300 I can help you change the parts over at my address.
Buyer has option to also take a set of unused DS2500 pads £100
shim spacer over disc hub face in the picture...
...also for sale outright - no exchange required. R33 GTs Twinpot setup with internal handbrake, fit under 16" rims, includes:
R33 GTs Twinpot callipers, good condition, all working
Blackstuff pads, decent
original Nissan 300mm vented disk, not warped/cracked etc, all good
Backplates, all handbrake internals, pads etc, handbrake cables from R33 GTs
Braided brake line to attach back to 200sx line - twinpot calliper has different fitting to the original calliper
This again is direct fitment upgrade, no mods required, everything is Nissan factory, and looks factory once fitted. Excellent brakes, easy pad changes, superior handbrake £300
2 February 2012
midlands
how much for the brakes with no exchange????
17 August 2015
UK
I'd need to find some standard replacements before I could sell them outright,
I'd be looking for £400
