R34GTT brake replacement
7 February 2006
Melbourne, Australia
I'm thinking of replacing the current one with a full one from a R34GTT, both front and back.
Are there any comments?
What are the exact parts I need? (Just to make sure I don't miss out any).
What do you think is a good price for it? (I can do the conversion..)
You should be able to get the calipers, discs etc easy enough, dont think they will be cheap mind.
Why do you want to change the front brakes? Getting bigger discs and better pads for the front will give a huge improvement :nod:
7 February 2006
Aren't the r34gtt ones larger too? I'm going for lighter, yet better brake performance.
7 January 2007
Perth, Wait Awhile
R34 gtt front brakes are abit bigger and can accomodate larger disc compared to the s15 ones.
But it's not bolt on, pretty sure the bolt size is diff. R34 uses 14mm bolt and s15s are 13mm so u might need to redrill the bolt size. Anything from R32/R33 is direct bolt on to s15s though.
Anyone got any details on how to convert to 2pot from r32/r33/r34?? Any particular things u need especially on the handbrake cable and all
Paddy mack
check out nicely's home page he has a how to covering your inquiry. its got pictures as well, part numbers are included. its top notch
