Hi guys,
I have some parts that are looking for a new home as I need more space in my garage! All parts are located in Hornsby (Sydney, NSW, Australia) with pick-up preferred.
Please contact me either via PM or at weisz_guy@yahoo.com if you have any questions or would like further photographs.
- S15 diff (centre and a few bits): $150
- S15 dual mass flywheel, clutch and all bolts: $100
- S15 standard anti-roll bars front and rear: $50 each
- S15 Aero rear wing and boot lid (pewter): $300
- S15 front calipers, rear calipers, rear rotors, master cylinder, pads: $250
- R32 GTR front discs (drilled - 50% after machining): $50
- R33 front discs (plain - 70%): $100
- 4" cat back exhaust 'Fujitsubo Giken' Main Factory (JASMA001) 98 R00037: $300
- 'ZZ' pedal attachment set (x3): $15
- S15 intercooler with all plumbing and fittings: $75
- S15 standard BOV (blow off valve): $50
- S15 suspension arms (camber arms and traction arms): $50 pair or $80 for the lot
- S15 left rear light cluster: $100
- Nismo S-tune (G-Attack) rear struts for S15 (56210-RNS50, KYB, YF06): $150
- GAB coilovers: $750
Adjustable height and shock rate gas platform struts. Front is top plate adjustable as well.
The coilovers were on the S15 when I imported it with 47,000kms - so have travelled less than that.
Front springs: HST80170-62 (8kg, 170mm), Rear springs: HST60250-62 (6kg, 250mm).
One front adjustment collar is cracked and now has a clamp to hold it - as per the photograph.
Thanks,
Daniel
Thanks,
Daniel
