Get a buddy to help you do it.
There is a certain order to do them in, cant remember which, but someone will pop up and say i'm sure.
But basically, get all of your brakes plumbed in, and start with one caliper. ensure the BMC is topped up, remove the bleed valve and put a tube (a length of boost pipe works a treat) over the end of it and the other end in a bottle with your old brake fluid or other liquid in it, doesnt really matter. then with that set up, get your buddy to pump the footbrake until you have a constant stream of brake fluid coming out, no air bubbles. repeat for all 4 corners, ensuring whilst the brakes are being pumped that the BMC remains topped up as its draining out the bleed valves.
when you're sure theres no more air coming out keep your buddy to keep their foot on the brake whilst you put the bleed valve back in, thus not letting the chance for air to get sucked in.
thats how you do it, its pretty simple. just check the order in which to do each corner.
