S15 model report
Jerry
I have check SVA UK and they don't have it and model report direct hasn't got either.
who can I rent the model report from? and how much is it? ?250?
Cheers
As Nicely said :nod:
If you're hiring the report and taking the car to a test station yourself. Check that they can get the S15 tested first. I think there's only a handfull of ESVA stations who can handle the S15.
Meddy
Also another thing to keep in mind is that the test stations can get funny about you prepping the car for test and not them.
Oh. Didn't know that it was the ESVA companies who also did the modding to the car.
If that's the case. It might be better to just turn the car in to one of the companies.
I have the reciept from BMS ltd at home so I can check how much it was. But I think it was around the ?1200-1300.
That included everything except the stock parts which I borrowed from "Kieran" and "Greg".
I dont think the same people who do the ESVA will do the alterations:no:
Although i may be wrong..................
Ok here we go. This is exactly what my ESVA test costed me last year.
BMS ltd said:
Model report: ?499.5
SVA conversion & test fee ?490.0
supply and fit immobilizer ?120.0
Swapped exhasut + wheels for test
and refit ?37.5
remove turbo-timer for test ?10.0
Total: ?1157 + VAT (17,5%) 202.47 = ?1359.47
Now after some investigating I'm pretty sure that BMS ltd and www.model-reportsdirect.com is the same company. It appears as they share the same roof and phone numbers :)
I haven't seen any other place with a S15 model-report.
Found this on the model-report direct website.
Complex modification is required and to ensure compliance of this report it is mandatory the conversion work and test is carried out using an ESVA specialist centre with working knowledge of the report.
To request rental of this model report please enter or select the name of the VOSA approved test centre you wish to use along with your vehicles chassis number.
Testing Station Name: BMS ltd - Bristol
Charlsworths - Donnington
Motor mall ltd - Gillingham
Vine Place - newcastle
