S15 specialist in Surrey?
24 June 2012
United Kingdom
Evening all,
as per title, any specialist in the area or not too far out? Need my clutch check out.. Makes a horrible grinding noise sometimes when fully depressed... Happens now and then... :(
Cheers.
2 March 2011
Croydon, Surrey
sounds like release bearing to me, does it only happen when cold/startup or ramdomly?
24 June 2012
United Kingdom
It can happen at anytime... Cold hot... But sometimes it would be fine... I sit at lights, hold clutch down, nothing, nothing, nothing.... Then, grind grind grind..... Pump pedal a couple times.. Would stop.. Then, if it feels like it.. It would keep quiet.. If not.. Again grind grind grind!!! :( it's a new bearing from drift works... Fitted before Xmas... Had a full clutch and flywheel conversion kit... Running. S14 clutch...
mattyb
28 October 2011
gateshead
Have you checked your not lraking fluid fromyour clutch lines. And bleed it too.
Max
31 October 2010
Cornwall
Garage D isn't too far
