- 26 October 2005
- Helsinki, Finland
- www.jull.net
I've recently upgraded my Snooper to a Syrius S600 and I now have my S6-R Neo for sale
These are selling on Ebay for upwards of £100.
I'm pleased to say that I can offer this to you for £60 delivered!
Here's the official spiel...
The Snooper S6 R Neo combines BOTH laser / radar detection with GPS satellite tracking so that ALL threats are covered. The S6 R also has a built in modem there's no need to take extra equipment with you to update.
* In Car Full Logic GPS Control Panel
* Compact Radar/Laser Detector
* Remote GPS Extension Antenna
* Professional or DIY Installation
The Snooper S6 R Neo has been specially designed to help you drive safely within the confines of today's speed limits, by alerting you quickly and easily to the presence of Police speed traps, often located at Accident Blackspots, electronically indicating potentially dangerous and hazardous situations.
Motorcycle Usage An optional ear-piece is available for use with Snooper S6 neo. The ear-piece is designed to transfer the audio alert to the inside of your helmet. You can purchase the ear-piece for £19.95 from the accessories list here.
Advanced Technology
The geographical co-ordinates of all 'fixed' speed monitoring systems and many officially designated accident 'hotspots' have been stored on a database that is constantly monitored and up-dated by a data collection team, ensuring that you are alerted to every potentially hazardous stretch of road or danger spot both audibly and visually via a speaker and LCD display, ensuring your highest concentration at all times. The Snooper
S6 R comes complete with a highly innovative built-in modem, allowing the device to simply plug into any compatible telephone socket and download the database in a matter of minutes. To ensure that your Snooper S6 R is always effective, downloads can be performed as often as the user prefers, subject to a valid subscription.
To subscribe to the Enigma speed camera database there is monthly charge of £4.95 payable (or £49.50 per annum) - or you can take advantage of a £99.95 LIFETIME subscription instead when you register your unit with. Registration details.
Radar/laser detection as standard
The Snooper S6 R Neo also comes complete with a radar/laser detector (RLD) that can either be mounted on the dashboard or inside of the windscreen. The S6 R radar/laser detector however is also waterproof and comes complete with an under bonnet mounting kit so that it can be positioned within the engine compartment behind the vehicles grille for a neat and professional installation.
The S6 R RLD has been designed to detect all types of radar and laser speed monitoring systems often used in danger spots where 'Fixed' systems cannot be easily utilised, thus ensuring that you are alert to almost every accident hotspot and speed monitoring system, whether fixed or mobile. Radar and laser detection is also selectable enabling you to programme the device to detect radar and laser, laser only, or can be switched off in low risk or high false alert areas.
Increased Awareness
The Snooper S6 R Neo is also equipped with a user selected speed limit alert system enabling the device to be programmed to alert you to any pre-determined speed you choose. Acting as a constant reminder of the current speed limit. The information that the Snooper S6 R can give is further enhanced by many usable selectable features. The LCD display can be programmed simply and easily through a Full Logic menu system to show your current speed, direction of travel and the speed limit and road number or name at each and every location detected, (except those detected purely by radar or laser).
Providing Advanced Warning Of
* Gatso speed cameras
* Truvelo speed cameras
* SPECS speed camera
* Radar and Laser guns
* Digital speed cameras
* Accident blackspots
* Most fixed and mobile speed monitoring systems
Installation
The Snooper S6 R Neo is a modular system and includes three separate components; a radar/laser detector, GPS antenna and Control Panel. This provides a number of easy fitting options in any vehicle as well as on most motorbikes.
The Snooper S6 R comes complete with a selection of brackets for installation, including 2 suction cup brackets for mounting both the control panel and the RLD unit in the windscreen, plus a specially devised mounting system which enables the control panel to be mounted almost anywhere around the vehicles centre console or dashboard, and an under-bonnet fitting kit for the RLD unit behind the grille if preferred.
The GPS antenna can be attached to either the vehicles dashboard or rear parcel shelf with a simple Velcro fastener.
It is advisable to place the GPS and Radar units at least 50cm apart to avoid unnecessary false alarms.
The Snooper S6-GPS consists of the Full Logic GPS control panel with built-in modem and the remote GPS extension antenna plus all relevant installation accessories.
Advanced Technology
Increased Awareness
Installation
