Well. I considering upgrading the front calipers on my Spec S to Spec R/Kings S14 twin piston calipers. Couple of questions I have about it:
As far as I'm aware they are a direct bolt on job to a Spec S. Am I right in saying that?
I know the pads are completely different but the only difference between the discs in the thickness. Spec S is 22mm and Turbo model is 30mm. So what I'm wondering is can I keep my 22mm discs and use them with the turbo calipers? Will the pads still contact with the discs when they are nearly worn down to the last, or will the pistons stop extending and not make up the 8mm difference and basically not stop the car? I'd like to keep these discs as they're only a few months old and are drilled and grooved.
Last question, will the non turbo master cylinder be strong enough for the twin piston calipers or will it need to be upgraded?
I dunno am I making sense with the second question but ye might get me. Thanks
