Stange Trans grind and electrical Q's
8 January 2014
Edmonton
Right after start up when the clutch is down I shift into gear and give it gas then I hear a slight grind noise, in both 1st and reverse. this is only after the first shift into gear before i start moving. when I'm driving there is no grinds and no problems getting into gear, the clutch has lots of life but is this a sign i should replace my clutch or does this sound like a much more serious issue with my trans?
Also will an s14 window motor and central locking actuator bolt up to the s15? my passenger window barely goes up and the lock motor is starting to die it barely moves but still unlocks and locks the door every now and then it wont fully unlock and ill have to manually unlock it.
18 September 2011
West Midlands, England
The trans noise is quite common, it's the release bearing i believe (correct me if im wrong anyone) My S14a did it, even when i changed the clutch and renwed the release bearing it made the noise after a few weeks. My s15 does it when its cold, as you described, only when engaging 1st or reverse. So nothing to worry about dude
The window motor problem i have first hand experience with - the S14 motor WILL NOT fit our S15's. I found this out the hard way, when my drivers motor went, i bought an S14 fitment one and it was way different.
8 January 2014
Edmonton
you have no idea how relieved I feel about the noise! and I am trying to locate the motors but I haven't had any luck do you remember where you got yours from?
18 September 2011
Yeah i wouldnt worry about the noise dude, im sure other people will chime in and say the same.
I got mine from http://www.japperformanceparts.co.uk/ - but they rarely have S15's in for breaking. BUT i have noticed some S15's being broken on eBay - drop them a message!
1.
http://www.ebay.co.uk/itm/Nissan-20...arts_Vehicles_CarParts_SM&hash=item2a3d63d180
2.
http://www.ebay.co.uk/itm/Nissan-Si...icle_Parts_Accessories_ET&hash=item19ed845cd4
3.
http://www.ebay.co.uk/itm/1999-NISS...arts_Vehicles_CarParts_SM&hash=item233ae7d5ad
4.
http://www.ebay.co.uk/itm/BREAKING-...arts_Vehicles_CarParts_SM&hash=item1c41179932
