AshOBNXZ
Hi guys,
My BLITZ water temp gauge has been playing up for a while and today since work was quiet we decided to look into it.
Found that whoever had it in Japan had somehow drilled and sealed the sender into the top radiator hose and that it is very slightly leaking coolant.
One of the guys I work with says it's in the wrong place anyway and it wants to be on the bottom hose to measure the temp after it has been through the rad, however someone else says it should be on the top hose so that it measures the temperature coming out the engine before going into the rad.
Any clarification would help because I have ordered a new set of silicone radiator hoses and a proper sensor adaptor for the job
Thanks
Thanks
