wheel size question
Hi guy's,I have had a bit of luck and found the wheels I always wanted for my car at a very good price,only problem Is I am not sure if they will fit.I was originally wanting 8.5's but the ones I found are 9.5 et 35 18's anyone know if these will fit???? Think they may be too big:(
13 June 2010
Pisa, Italy
www.flickr.com
They should fit pretty well, may need to roll the rear fenders. I'm running 18x9.5's +20, no fitment issues on the front, the rears needed pulled a little. I'm only running 235/40-18's though. You should be able to use a 255/35 on the rear I'd imagine.
5 March 2009
qld,australia
Yeah would say they should me right.
cheers for the info guy's,hopefully should be getting some new wheels then!!!!:thumbs:
The fronts will be fine, but the backs you will need to roll the guards to stop scrubing in bumps and corners. I'm running 9' + 38 in the rear and still needed the guards lipped
That's cool man,I am getting all my arches rolled for 40 quid!!!!bargains!!!would the handling be better with 8.5 front and 9.5 rears???or would it not make much difference...
Wider tyres will help,but its the sum of numerous suspension up grades and alignment settings that will ultimately give you the performance handling ;)
Well I have full set of adjustable arms,uprated arbs,front and rear struts and tein superstreets with pillow ball top mounts,so got quite a decent set up as it is just not sure if it would handle better with 8.5 on the front and have less stretch on the tyres??
