Wheel Size/Spec
6 March 2017
Ashford
Hi,
I've recently imported an S15 Spec R and have plans for the bodywork, which include 30mm wider front wings and 50mm over fenders for the rear. I'm not sure what size/spec wheels I will need, can anybody help or be able to point me in the direction of someone with a similar set-up who I can ask for advice?
Thank you.
You can use online offset calculators to decide
I have 50mm wider front and rear
Run 19x9.5 et-14 up front and 19x11 et10 in the rear : loads of room and decent size tyres as well .
18 is the usual choice I just went 19 because the kit is massive and they look lost . What sort of look are you aiming for ?
6 March 2017
Ashford
Thank you, I'll take a look =]
Sounds like I'm potentially looking for 18 on the front and 19 on the back, judging by what you have for yours.
I want the wheels to have a fitted look and not look lost, as you said about yours.
Yeah man double staggered looks perfect imo the only reason I didn’t get 18’s on the front is the wheels I wanted were only available in 19 at the time !
I can grab some photos of mine later on if you like
I run 275/30 on the rear of mine , could get a 285 on pretty easy so you don’t have much stretch .
