Where is the engine ground?
7 February 2015
Maidenhead, Berks.
I'm suffering from possible grounding issues to the ECU and from the S15 service manual it grounds to the engine ground F37.
Where actually is that though as the diagram isn't that clear and I can't see anything obvious on the engine!!
16 August 2013
W.Mids
On the inlet, next to the fuse box. The ECCS harness grounds are on the back of the inlet.
7 February 2015
Maidenhead, Berks.
Hmmm had a very quick look this morning and couldn't spot anything that looked like it. I've got a greddy intake so would mine be somewhere else?
sibbers
11 February 2015
Twickenham
Your engine ground was attached, its a thick wire that runs to the inlet near the turret. There is another at the rear by exhaust manifold/heater matrix hoses which was also attached, and I'm not sure where the others are tbh...?
