where to get Head gasket + head bolts
29 July 2013
Derby
I think my head gasket is leaking oil.
Does anyone know where to get a standard gasket + bolts
or which aftermarket one is best, I hear metal ones aren't good. or theres that Cosworth multi layer one, but its got many options 87mm bore, 1.1,1.5,1.8 thickness & 90mm bore 1.1,1.5 thickness?!
Where to get oem head bolts or what aftermarket is there?
any help would be great! thanks.
Also is there anything that should be or can be checked & replaced if needed while the head is off?
willy s15
25 January 2014
greece athens
hey mate i friend of mine he has metal tomei ( one of best ) 88mm and 1.5 thickness
it is import from japan from wrong order ( he order 87 and he got 88 its alright order from other dealer )
so gasket is in Greece its the original box its brand new untouched
take a look on this http://www.car.gr/parts/photos/6597825/
price is 100 pounds ship it to your door
i think you have check it out head if its ok change valve stems seals
and its ok
29 July 2013
Derby
I don't really want a metal one, they can leak apparently & im running less than 300bhp.
