X-Trail Coils in a S15
5 October 2009
are X-Trails coils the same as the S15?
have seen them advertised as being compatible,
http://cgi.ebay.co.uk/SPLITFIRE-DIR...arts_Vehicles_CarParts_SM?hash=item5631f2a5d9
the reason i ask is my car is still having misfire issues and im waiting for a new set to turn up but there is a guy with some X-trail coils local that i could use till then,
so i can actually drive the dam thing without it ****ing up on me!
So can i use X-Trail coils in a S15? they came from a 2002 model and are brand new.
They should,the only thing that might be different is the bolt hole location on the coil pack.
My wifes XTrail has a different angle on the tab for the bolt to attach to the rocker cover
5 October 2009
Thanks for reply,
how far apart is the bolt holes between the s15 and x-trail? will it be easy to modify
5 November 2008
Hertfordshire
Hmm this is interesting! Good to see there might be other options!! :thumbs:
Thanks for reply,
On the S15 the bolt tabs are right angles to the coil pack,on the XTrail they are at a slight 45 degrees to the coil pack
go out and had a look did we phil? :p
