Z32 afm?
14 May 2011
northamptonshire
hi,
what does a Z32 AFM actually do?
thanks
james
24 November 2009
North Yorkshire
Its just an air flow meter from a 300ZX :)
Similar to the one on your S15, but (i think) it can handle a larger airflow and still measure it accurately as the Z32 has a 3 litre twin turbo (if you get the top spec).
I think people get them if theyre running a lot more power for the above reasons. You will need a remap once fitted as your standard ECU wont recognise the part :)
14 May 2011
northamptonshire
ahh right cool mate :) as you can proberly tell i dont know an awlful lot haha
24 November 2009
North Yorkshire
haha i only know what i know because i've spent a lot of time on this forum! hahaha
29 April 2009
Or you can run an ECU like my F-CON. Does away with an air flow meter completely and uses MAP sensor instead :)
The stock AFM is 55mm diameter,the Z32 is 80mm, quite different to each other. The Z32 has good resolution for measuing air flow through the rev range.
