my s15 slowly seems to be getting more more unrealiable.
sometimes it will boost fine and pull through all the gears but most of the time it splutters alot and feels like it has now power? feels like someone keeps pressing the brakes hard then letting off. also it backfires alot very loud with alot of black smoke on the backfire? when you finally come to a stop it stalls and takes alot of turning over before it starts again.
On idle the needle jumps around alot, the revs will keep dropping then picking up but then eventually stall.
seems to be one problem after another with this car....
ive checked spark plugs, AFM, changed the coilpacks and checked for boost leaks?
what else can i check? ive tried to read my power fc when it does it but everything seems fine?
proper stuck.
any help would be great
proper stuck.
