 - 17 January 2012
 - Essex
- @kwalker88
I've had a bit of an issue with my exhaust manifold causing the paint to bubble on my bonnet and now I'm having the car fully resprayed would like to find a solution
Are there any exhaust heat shields available on the market? I've seen heat shields for the ABS system but need something to prevent the temperature of the bonnet directly above the manifold rising. I've already tried some aluminium reflective foil on the underside of the bonnet which made no difference. The manifold was previously wrapped which had no effect either
Has anyone else had a similar issue and found a solution?
