- 2 October 2015
- STOKE-ON-TRENT
- www.ejmcarphotography.co.uk
- @lil_ej_x
Where can I grab one from?
Need one front ...
Need one front ...
Yeah I’ve been looking at the Mtec discs for the same reason. With the black coating, rears are just under £70 for a pair which is pretty damn decent. For how I use the car and what I use it for I really can’t be bothered with doing a full on conversion.For discs I used a company called brakedepot and got some grooved discs. They were fine and a good price but mine were for Z32 conversion, 200sx/s14/s15 look the same but use a solid disc. Mtec brakes I've used too and they were good price for drilled and grooved. Having said all this it's far better to go with a 2 pot conversion with integral handbrake and ventilated discs from a z32/r33 but it's a lot more involved needing the backplates, cables, calipers, hoses and internals as well as discs and pads. I had this setup with braided lines, stock bmc, bmc stopperand k sport 8 pot 330mm fronts and that thing stopped!!!
I did see that on my searches but they’ve been out of stock for months :lNISSAN SILVIA 200SX S14 S14A S15 REAR CALIPER REBUILD KIT MADE IN JAPAN - NISSAN PARTS - Products
as i said...JSP are the nuts![]()
Riiight ok, I’ll do that then. At £24.99, can’t go wrong.If you contact them directly they will source them for you direct from japan. they import stuff all the time but as said mainly honda stuff so they dont replace other bits so frequently
